Headers
Shorty headers aren't very effective on these engines. Several people have installed them and realized little difference at all. Long tubes are the way to go but it will require a rework of the entire exhaust system and new cats. I'm sure others will chime in here.
Go check out Jegs.com or Summitracing.com
I bet they have some cool stuff.
I for one!
I for one!
Funny thing is that the BBK shorty setup for Mustangs is the hot ticket. Their OEM manifolds must be a lot more restrictive than the 4.8 / 5.3 / 6.0 GM V8s.
I for one!
have you seen the manifolds on the fords , theyare wraped w / ss wrapping paper because they look lik a 5 yearold cutup a bunch of tubing parts & peices & glued thjem together , anything would work better than that
:sigh:
My Bro didn't like his JBA/BBK shorties. He replaced them with long tubes due to excessive under hood heat. (93 mustang GT btw)
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
