4.3 To 454 Swap Bugs, Need Help
I have a 93 swb that was a 4.3 V6 and I have converted it to a 454TBI 5-spd, I put 3/4 springs in front and a 342 posi rear to make it all right, used V6 harness with 454 computer. the engine Idles high and when in gear decelerating she will stumble every other second and it feels like she is loosing power after bout 3500rpm.
I know lots of issues but as much as I have put into her it doesnt seem like much to me :seeya: I am thinking that one issue is that the 454 computer was in a auto trans truck ( maybe high idle prob?? ) and once it gave me a ECT code but hasnt since.... and last issue .. what is the timing set for a 454 TBI ... I have heard 4* and 0* ???
If I cant get this thind right Im just gonna rip out the distributor and throttle body and throw on a carter 1100 and HEI and call it a day but would like to keep fuel inj if I can
Any comments or Idea's would be most welcome ... thx
Get a memcal burned for a 454 manual by a programmer and you should be OK.
any idea how I go about doing that
Meaning who, where, and how to contact
I take it that memcal it the chip in the ECU?
Do a search and someone here may know, the Memcal is in the PCM. Who ever makes you a new will provide the Memcal. The wireing is different between a v6-v8 and a big block so if you havent changed the pin outs do that first so when you get a new program it works correctly.
the Wiring harness matched right up aside from having to extend the TPS wires bout 1 inch, I have found one of my injectors was pouring instead of misting at idle, so thats step #1 :uhoh: now I just need to get a custom burned chip and find out what the timing set is
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
