05 Avalanche, Problems With Cd Player/ Res
jason401
Hey Guys, I just recently bought an 05 Avalanche 1500 w/ 6 disc CD player and RES. When I tried to load a CD into the System nothing happens, if you hold down the load button, it beeps but the green light dosn't blink and it will never take a CD. I am assuming there is no easy fix to this but figured I would ask.
As well with the RES when you pop in a dvd and play it everything works except the sound. there was no wireless headphones with the truck. When you plug in wired headphones in the back you can hear the radio but nothing from the DVD player. as well as I can't seem to even get any sound for the DVD out of the truck speakers. anyone got any idea on this? or am I buggered and have to take it in to get fixed? thanks for your help
Jason
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 280 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
