Help My Tranny Is Blown What Fits 4l60e Interchange
i need a trans for my 2000 yukon
one of my friends has a pile of them sitting on the shelf ready to go
he buys wrecked vechicles from the auction fixes them up to sell
he also buys totally destroyed vechicles and parts them out
http://www.bobsauto111.com/welcome.php
any way what should i be looking for their all labeled by what they came out of
he has a really cleans trans with 23k from a 2006 trailblazer that had a 5.3
it looks like my trans will it work ?
if not what do i have to due to make it work???
what other years will fit
i also saw one from a 2003 z-71 will it work
and a 2wd trans from a 2005 silverado with a 5.3. will that fit if i just swapp the out put shaft
i need help
i planatary set came apart in my trans a destroyed the case and filled the rest of the parts with metal
thanks again
A 4l60 is a 4l60 for the most part...if you have a 2wd...you have to use a 2wd trans...it has a tail shaft, where the 4wd model has a transfer case attached to it instead.
If your Yukon is a 4wd you can use the z71 one or the trailblazer if it was a 4wd unit. If you have a 2wd Yukon....(did they even make one???) you can use the 05 Silverado one
Hollander lists 99-00 Silverado (w/o ext cab) & 00 Yukon, Suburban 5.3 to be the same as far as being a drop in fit. Like others here are saying the 4L60 transmission from another GM may work with modification. I'd probably get with a trans shop for further recommendations.
Hollander interchange number is 400-03455
Yea, the boneyard interchange lists 99-00 Silverado and Sierra 1500s as well as Yukons and the Tahoes. (non XL, 5.3l 4x4)
    CaptainDad
    CaptainDad
  • Who's Online   0 Members, 0 Anonymous, 651 Guests (See full list)
