Squeaking From Passenger Front
Hey all, yesterday for the first time I noticed that I have a very annoying high pitch squeek that comes from the front passenger side of my truck. I originally thought it was a body connection or body mount, but its more and more pointing to the front wheel bearing. The squeak does not correspond with acceleration, deceleration, turning, suspension input, etc of any magnitude (I cannot find a correlation between the squeak and anything else that is reliable). I removed the front tire and realized it was when i rotated the hub that it made the noise. The brakes weren't hanging up but I found it very tough to spin too. What does it sound like? Front hub/wheel bearing? Thanks
BTW, this is on a 2006 silverado 1500 with stock rims and tires. I have 39k on the odometer.
Does it stop when you apply the breaks or get louder when you take a curve? sounds like wheel bearings.
Neither very reliably. It does it mostly when just cruising along in a straight line. If it is my wheel bearings, what has to be replaced?
wheel bearing would be wheel speed consitent and tends to make growling noise not squeaking. also with wheel bearings it getrs worse on turns if you turn left and it gets worse its your right if you turn right and it gets worse its your left. also with wheel bearings in the front your abs light will come on. if it is a wheel bearing in the front the whole hub will have to be replaced which is 200 dollars at auto zone. is the noise wheel speed consitent? i had a squeaking in mine that was an A arm bushing let me know what you find out
passenger issues? :cheers:
Jack up the front of the truck, put it on jack-stands, grab the tire in question at the 12 and 6 o'clock positions, and try to wiggle back and forth. If there's any play that isn't coming from the ball joint, your hub/bearing assembly is bad. And the whole hub needs to be replaced.
^^^ One thing you forgot dan:
If you're checking for balljoint play, you want to jack up that tire from the lower control arm and then grab/wiggle the tire like dan described.
If you let the suspension sag from jacking at the crossmember or frame, pressure gets put on the balljoints as the suspension sags and you may not see any play in the joints.
    Brendan C
    Brendan C
  • Who's Online   0 Members, 0 Anonymous, 876 Guests (See full list)
