Few Qustions For Parts I Need To Get.
how easy is it to remove a rear window on a 88 c1500 to a 97 c 1500 ? i want to put a rear slider in my truck i was told its as easy as cutting the expoxy that holds it in .
next qustion
i was under dash trying to figure out why i have no dash vent but i have deforst and floor vents . i found out the linkage under dash were cable attaches seems likes its stuck its the cable type , to replace all this to get dash vents to work what parts do i need to get from junk yard?
thanks in advance guys and girls.
Hi Ross,just now saw your thread....my Haynes manual doesn't have any instructions for removing the rear glass.Here's the paragraph:
''Replacement of the windshield and fixed glass requires the use of special fast-setting adhesive/caulk materials and some specialized tools and techniques.These operations should be left to a dealer service department or a shop specializing in glass work.''
With this in mind remember the epoxy they use is quite strong and I believe the pros use a cutting wire with a handle on each end,pulling back and forth to ''saw'' the epoxy loose.
