Plastic Nipple Broke On 99 Sierra
sierraingws
99 Sierra 2500, 200K, 6.0, auto, AC, 4wd, Last week one of the plastic nipples the heater hose is connected to at the firewall broke while driving. I have begun the dash removal process (sheesh, what a pain), and have new core coming, but some disscussions here make me think that the plastic piece is NOT part of the core. If so, how can I get it off without removing the core (and the whole dang dash)? The hoses were connected with pinch type clamps. AFAIK everything is stock. \
Thanks
The heater hose disconnects, are removable. You will need a quick-disconnect tool, to slide in, from the back of the connector, then pull toward you, to release it. You can buy the Lisle brand, at Pep Boys. It has 6 different sizes, and are longer that fuel disconnects. Put your dash, back together.
Thanks. After looking at it some more I could see that there was indeed a piece slid over the metal end of the heater core. I cut it off with a sawzall blade, applied some heater hose stretcher and sliped the hose over the (now) metal end. If you ask me, this is the silliest thing I have seen in the 10 yrs I have had this truck. Adding a plastic piece that requires a special tool is a goofy solution to a packaging problem- that is that the metal end of the core is tucked a bit under the cowl and behind the engine.
Now to put the interior back together.
Thanks again.
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 826 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
