Banks Monster Exhaust?
Anyone using a Banks Monster Exhaust system on their 5.3L V8 truck? If so, how do you like it overall? I'm starting to look around at cat-back exhaust systems and since I just finished installing a Banks Ram-Air CAI I thought I might try their Monster Exhaust kit. I'm not looking for a loud exhaust that will wake the neighbors or prevent me from carrying on a conversation in the cab while I'm cruising down the highway. I'm after a nice aggressive V8 exhaust tone while accelerating, but tame while cruising in OD. I'm not locked into the Banks exhaust just yet, so I'm open to suggestions. Thanks.
No, Banks' stuff is pretty pricey...I'm happy with my MBRP exhaust, much better than the flowmasters.
no one that I know of has a banks exhaust on their gas truck. Most people will lean towards Corsa (pretty expensive), Magnaflow (less expensive in comparison), and flowmaster.
Flowmaster is generally the loudest, but that depends on which muffler you get. They are also known to drone inside the cab while you're cruising. If you live in the north where the roads are salted in the winter, its common for these mufflers and systems to rust out in a couple years because they're made of alluminized steel.
Corsa, supposedly (I've never had it) doesn't drone at all, and has a nice agressive sound. All stainless construction makes these durable, but expensive.
Magnaflow gives a nice mellow tone, but some complain it isn't loud enough. Again, all stainless construction makes these a good buy as they are generally about 1/2 the cost of a Corsa.
hope that helps some
good luck
I had a Banks System on my 05 Frontier, I didn't like it at all, removed it after about a month and sold it. Now it may be different on a V8 (the Frontier was a V6), but it had a horrible drone in the cab at highway speeds. Bad enough to drown out the stereo! I would be cautious of the Banks system on the 5.3L with variable cylinder management (V4/V8 Mode) because I have read about other systems with bad drone when the engine is in V4 mode. I do know the GMPP and Corsa systems reportedly don't have the drone in V4 Mode. With you having an 06, this may not be an issue for you.
Personally, I'm satisfied with the sound/performance of the stock exaust, and unless you really wanted the look of dual exhaust, there isn't much difference between the stock exhaust and a single out aftermarket exhaust other than possibly the muffler.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
