Heated Mirrors
Well i noticed that the 99-00' Escalades had heated mirrors that are like the mirrors on my truck.
i want to get them but where is the button located to turn them on and off?
It's tied into the rear window defroster.
They use the rear window defogger switch (IE-When you turn the rear window defogger on/off the heated mirrors turn on/off)
is the defroster where the cargo light button is or is it above it?
You know to the right of the steering wheel there is like 3 squares made for buttons/ switches
Nope,Its in with the HVAC controls.
nope, part of the HVAC controls...the rear defroster button has a pic of a rectangle (window) with 3 squiggly (is that a word?) lines through it.
Does your truck have a rear defroster? Just look at the glass, can you see the lines running horizontally
On some vehicles I've worked on, the rear window defroster also has a relay and a connection to the engine computer. So if there is existing wiring for this, also look at the wiring diagram for a spot for a relay.
The reason for a computer connection would be so it could monitor all the electrical loads and add more power as more things are turned on (headlights, fog lights, A/C, etc.)
    FiLo
    FiLo
  • Who's Online   5 Members, 0 Anonymous, 656 Guests (See full list)
