Auto Transmission Question 1993 C1500
I have a 1993 Chevy C1500 with the 4.3 liter engine and automatic transmission and have a couple of questions:
1)Which transmission is installed in this pickup?
2) The transmission will not go in reverse. Forward gears are OK. Is there an easy fix for this or am I looking at an overhaul?
Thanks a million for any info!!
1) dont know for sure, prolly 4l60
2) prolly valve body (experience)
I am sure others will respond with better ideas
1) 4L60E
2) Depends
When was the last time the transmission was serviced? It could be a blocked port in the valve body or worse a bad syncro.
I'm not sure when it was serviced. I got the truck from some friends, and I suspect it hasn't been serviced for a while.
A guy at work had the same thing happen, where reverse went out. He drives the truck kinda hard. It's a 95 Silverado. Yours is likely the 4L60. What this guy did for a while, was pull into his spot so he could drive out, but letting it roll backwards. :thumbs: He eventually got it rebuilt after it grenaded a few weeks later.
    BigJake
    BigJake
  • Who's Online   4 Members, 0 Anonymous, 652 Guests (See full list)
