97 Blazer 4x4 ,transfer Case Question
I have a 97 blazer 4x4 that I've been piddling with. Something seems to be wrong with the 4wd Lo gear. When I press the dash mounted transfer case switch (button) the 4wd Hi button will light up when pressed and I can hear a noise under the shifter/console area, sounds like a solenoid engaging. But when I press the 4wd Lo button the button doesn't light up steady lit like the 4wd Hi button does. It just starts blinking when I press it, and I don't hear the solenoid engaging like when its in 4wd Hi. I have no clue what do do from here or where to even look. What could be wrong and what should I look at or try and test? I'm wondering if this may be something as simple as a computer or wiring glitch or even a bad solenoid. Or then, could it possibly be a bad transfer case? Any ideas at all?
:puke:
Could be the switch, or worse the TCCM(Transfer Case Control Module).
You say peddling with, was this wrecked on the like? Have you verified the wiring?
OK, when I say piddling with, that means its my project-not my daily driver. It was my brother's blazer and he gave it to me for free (I just had to tow it here all the way fromBaton Rouge). He bought it used about 2 years ago and never even tried to use the 4wd at all that whole time. All I did was put in another switch (used switch but they said it was 100% functional and 30 day warranty). I'm still trying to diagnose every problem on this truck before I determine if its worth fixing up for a woods truck (hunting truck). I found many other problems, but now I'm trying to figure out the 4wd and see whats up with it. The last thing I wanna do is fix the cooling system, and spend $100 bucks on tune up parts, and rebuild the suspension and everything and then find out the transfer case is shot. I wanna know EVERYthing before I fix anything at all on this truck. You see where I'm coming from? I'm just clueless about this 4wd and I'd like to know what the problem is and how serious it may or may not be.
And is there any way to test this Transfer Case Control Module? And any idea where it would be located? And I only paid $10 for the used switch, maybe I'll buy a new one (which I beleive is aftermarket) off ebay for like $40 shipped. But then gain, I'd rather not buy another switch unless it is HIGHLY likely that its the cause of the problem. The previous switch didn't light up at all, but I still heard the solenoid engaging noise when I pressed 4wd Hi and then back to 2wd, but nothing in 4wd Lo.
I am not sure on the test procedure. I only have a 2WD. But the TCCM should be located on the drives side kick panel. Check all the connections there. I would also check the connection going to the t-case. There is a possibility that the encoder motor(in the T-case) is either not operating correctly or is not getting a signal from the TCCM. You should check out the blazer forum. Those guys are pretty knowledgable.
Stupid question, but is it in neutral when you try shifting into 4lo?
...Oh yeah, good one. I assumed this was done.
I tried it many times, both with the old switch, and the replacement switch. Tried it in park, drive, and neutral. Same result every time, the light just starts flashing.
Thanks Draenor, I joined that Blazer forum and I've already found a mountain of info by searching old threads. :D
    • 3.59 Kroger’s in Montgomery Tx. 20 cents higher than most around here. Very unusual. Saturday they were 3.49.
    • Starting at 17 running parts for my father’s construction business to haul our equipment. Eventually doing shows, sales and training after purchase. I drove a minimum of 50K miles a year. Half hauling something. After retiring 30K miles a year to the last 2 years 15K miles a year. 2/3rds highway driving. The major contribution to fatigue for me is from anticipation and awareness. I just don’t relax. Too many idiots on the road. There’s two kinds. The group that never leave the left lane tied together afraid to let anyone in doing 80. They’re mostly on weekends. Then the left lane sleepers usually next to a tractor trailer not advancing. Eventually the tractor trailer will drift over the sleeper will wake up. The train moves and the tailgaters who are usually mad as hell. You definitely don’t want to mix with them. The tail wagging bumper puller’s with under powered trucks are holding the tractor trailer up. That bunch are dangerous. I usually pace ahead all that. Unless there’s a gap when I can chill and let the speeders pass. I tried all different types of driving. I stay to the right except to pass, it’s the law that’s getting in forced more now because of road rage. I was so happy when my wife didn’t want to do the camping life. I had enough of pulling for work. The family has a bus and fifth wheel. I haven’t driven either one since retiring. No thanks.
    • Yesterday a suggested youtube video thumbnail caught my attention so I watched through it and it was a bunch of short clips someone gathered together of people pulling trailers, a lot of them were bumper pull holiday trailers and a pickup or suv pulling it. a few fifth wheels as well, some motorhome crashes also. The tail wagging the dog theme was quite evident in numerous self inflicted accidents that took out vehicles around them sometimes in the process as the unit finally swung around and flipped over in the middle of the highway. Or the other classic which literally could be called "I forgot the trailer was back there" in passing another vehicle on a multi lane one way freeway and then cutting back in line before the back of the rv trailer had passed the front of the passed vehicle and often in front of a tractor trailer and that never ended well. Or the wide kick out swing of the rear of a long travel trailer as they have so much overhang behind the axles and the trailer smashes into the side of vehicles in the next lane over ( typically sharp turns in city driving ). It makes one leery for good reason to be near an RV trailer after watching a video like that and be it on the highway, in town, or at a gas station where that rear end comes swinging around due to the fuel station being so cramped and not intended for larger trailers. I wonder how many officers have heard those words though "I forgot it was back there" as they investigate the accident LOL.
    • $5.10 for regular at the Kroger   It's been 6 months... is this the "new normal" ?
    • Just because a person can buy a travel trailer or a motorhome doesn't mean they can drive it properly. My observation during my RVing years.
