1998 s10 with 150,000 miles. Started out stalling out when stopped. Has gotten worse. Now engine cuts off and will not restart. Have replaced module, coil, and crank shaft position sensor which have not fixed problems. fuel pump is running fine and pressure is ok. Any suggestions on what to check next?
Before you spend that second half of a million dollars sort of guessing what's wrong, I think I'd take it to somebody that works on them all the time. Sometimes, it saves you lots of $$$ in the long run. Even with the fuel pump running, it doesn't necessarily mean that it's providing correct pressure.
I'd really consider having somebody take a look.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,025 Guests (See full list)
