I Need Your Help With A Sub Problem.
Yo so i got my sound system in and its nice and all (pics soon yes) but my subthump box only has room for a shallow mount sub (and i went with this Alpine Type-S 10") It wasnt loud enough for me so my buddy and I turned the gain up a little bit on my 500 watt mono amp that is used just for the sub.. and then later when we were driving the sub blew out, and i wasnt really sure what happened but it def blew out. We were in a hurry since it was prom and stuff so we had a bunch of stuff to do and didnt have time to look at it. After prom we went back to this girl's house to what i thought was party since we had partied at her house before but her mom didnt let us and I had a 24 pack with my name all over it. but it is still unopened. anyways back on topic, so we never did look at it and i ended up coming home at 3 in the morning cuz the night was so gay since everyone went home or to sleep. this morning i woke up and started playing with it and stuff and i switched out the 10 sub and used my 12 sub in a box from my accord and it worked great. So what i want to do is this:
I want to somehow buy / make a 12" sub enclosure for an Alpine Type-E 12" because I just feel that the 10" shallow just wasnt good enough... and not to mention its ****ing BLOWN OUT THE DAY AFTER I GOT THE SYSTEM INSTALLED. What do you guys think happened? What should I do? What are your suggestions?
Edit: added the links to the subs.
Anything CAN be blown up. If you are wanting 2 12s worth of bass out of a single shallow 10, it's entirely possible that you overdrove it and burned it up. 50 watts can take out a 250 watt rated sub very easily if it is overdriven.
Sounds like you've cooked one.
Dukers,
Sounds like you probably fried the voice coil.
You have a 500 watt amp.
The shallow sub can only handle 300 watts..MAX and probably should be kept to NO MORE than 150/200.
From the website....RMS Power Range (Watts) 50-300
If you don't know what the term "CLIPPING" means...look it up.
It will fry your subs and speakers easily, even if they are running at far BELOW rated max output.
BTDT :thumbs::) More than once. :lol::lol:
FML
got a bunch going on and i feel bad for basically throwing away my moms money.
I've fried a few. Youth is pretty enthusiastic. I loved loud music. I mixed sound for bands in my 20s and left a bunch of my hearing there. Now I am a little less likely to destroy what I have left and it saves the equipment.
FML
Whaaat?
FML
Whaaat?
Yeah.The stupidity of youth! :thumbs: Luckily I stopped before I lost a major portion of my hearing. Hard to make any money in music but damn was it ever fun!
FML
Whaaat?
These will help ya out!
:thumbs:
FML
Whaaat?
:cool:
LOL!!!!
Dukers, just look on line for a box for twelves, or like you said build your own, I have only ever blown one sub, in the many I have had...if you have an extended cab you can fit the amp behind the back seat against the back wall, just wrap the back in box carpet so you don't hear it bounce off the wall, I need to do that mine still, I also need to carpet and polyfill my box still but I haven't yet, but I will some day..
I don't think I have ever broken in a sub in before...they should come pre-broken in, I though that they ran testing sweeps that counted as the break in...
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 640 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
