Brake Controller Install Location
Next week the RV shop is installing a prodigy brake controller in my truck.
I hate driving a truck and the controller is in the way of leg room or I kick it getting in.
I was wondering if it could be installed in the center console ( i have the slt dash).
Before the shop installs it, anyone have any suggestions as to the best location so it wont get in the way.
thx
thx
I have the same dash, and mine is in a great spot. Search out my install thread.
hmmm it looks far enough out of the way and I will probally end up putting it where you did...I just dont want to see it....I only tow 4-5 weekends a year
I have mine just below the shifter, used one of the retaining screws on the lower dash panel for mounting location...I used the detachable mount so I can just unplug my controller (P3) and tuck the connector behind the dash...Does not interfere with my leg (only if I really lean foward or bring my leg up while sitting.
Some pics- pardon the floor, hard to keep it clean when half of the areas I park in are grasslands...
I put mine on the other side of that strut that comes down beside the accelerator pedal. This way there is no way at all it can get kicked. I use a Prodigy in a plastic pocket holder, and all I did was attach some heavy duty velcro between the pocket and dash, and attached the two pieces together. I then put a sheet metal screw (with wide threads) through the pocket and the plastic console and that held it snug. The harness is run up out of the way. This location is perfect for accessibility and visibility. Here is a picture.
i like that idea but I have a center console there....I may see if they can install it inside the console instead.
You can mount it anywhere with a dremel tool and some L brackets haha...But I didn't want to cut up my dash and couldn't really figure out how it would fit in the ashtray (which I don't use) like some people claim to do...But really the only time I come in contact with the controller is when I slide forward and it touches my knee...Other than that I have not had any problems in my daily driving with it attached, and with it off I don't have any contact whatsoever and getting in I have no problems either...And I'm 5-10 200 lbs...
I put mine in about the same location as Outbacker. It's out of my way but within arms reach when I need it. The nice thing about the Tekonsha Prodigy and the P3 is they're gray and black, and it matches the ebony interior very nicely.
I put mine in the same spot as yours TxQuarterHorse using one of the existing hex screws that holds on the lower dash. Even with my floor mounted 4X4 Shifter there hasnt been any problems. Gotta love the Prodigy; set it and forget it.
thx
My prodigy velcros to the right of the dash above the accelarator. When not in use it just unplugs, slips into the cloth bag that came with it, and rides around in the glove box.
thx
When I sit in the truck there is not much room between my shin and the dash so I think I am going to velcro it and unplug it for daily driving
thx for the idea
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 966 Guests (See full list)
