Green/White/Checkered????
MountaineerTom
From Jayski's
Overtime? UPDATE: Winston Cup series officials are considering adopting the so-called "green-white-checker" rule used in NASCAR's Craftsman truck and other series. The rule, essentially a NASCAR version of overtime, says every race must end with at least two laps of green-flag racing. If there's a crash in the closing laps of a race, officials wave a red flag to signal drivers to stop on the track. NASCAR cleans the track and, if necessary, adds a lap or two. Other forms of racing don't bother with stoppages and simply finish some of their races under a yellow flag. Every major U.S. sport has a provision for overtime, but NASCAR faces additional challenges: By conserving fuel, a driver sometimes can make one less pit stop than his rivals and win a race. But if a car is running on fumes when NASCAR adds laps, that team gets punished. NASCAR officials are concerned that a second-place driver's teammate might be tempted to crash his car on purpose, giving his buddy a better chance to win.(in part from the USA Today)(3-6-2002)
UPDATE: NASCAR is studying the possible implementation of the green-white-checkered finish system, but no change is imminent. For now, it will continue evaluating each late-race situation on its own merits. “There is a lot of serious thought being given to some form of the green-white-checkered, so that the races can end up green-flag conditions,” Jim Hunter, NASCAR’s vice president of corporate communications, said March 1. “The hardest thing is when you run out of time, you run out of time. There’s so many things (to consider) that it’s not just as simple as just ‘Put the red flag out.’ It’s, ‘Where is the debris on the track?’ and ‘When did the caution car pick up the leader?’ “But I think there’s some real serious thought going in. We’ve thought about it before with the green-white-checkered and the minuses have always seemed, in the Winston Cup division, to outweigh the plusses. But it’s back on the table and I know there were several conversations this week. But until we make a decision, it will be a case-by-case basis. But everyone in NASCAR wants to see the races end under green as well and, hopefully, that will happen.”(Winston Cup Scene - need sub to read)(3-7-2002)
The NCTS and NASCAR Late Models don't seem to have a problem with the "Green, White, Checker" rule. Why would WC? Teams can and probably do work out "cautions" under the current set of rules.
I don't see why that was even brought up in the discussion.
I have been to WC and BGN races that finished under caution. I felt ripped off. That's kinda like going to a pro football game with a 3 point difference and calling it off at the two minute warning.
Since decent tickets at most WC events are upwards of $100.00, a finish under green is the least that the fans deserve!
For one, if they do this, everyone will know in advance, instead of on a "case by case basis" as NASCAR says about the red flags.  Pluss they could also just keep going around the track under caution, instead of stopping, then get the G/W/C flags.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
