Cluster Failure
Hi All,
Been a while since I have been in the Forum. I was just wondering if anyone has had a problem with the gauge cluster in the gmt900 trucks. Over the weekend my fuel, tach, and speedo died while going down the road. They came back after shutting the truck off and restarting a couple of times. Went to the dealer this morning and they said they could not find or see any evidence of this problem. Funny thing is onstar shot me an e-mail saying I needed to get my truck to the dealer. How the h#ll does onstar see this issue but the dealership does not? My tranny has been shifting funny lately. Could this be realted? My truck is an 08 rcsb 4x4, 5.3, 4 speed auto. :D
    bellssn690
    bellssn690
  • Who's Online   5 Members, 0 Anonymous, 718 Guests (See full list)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
