Heater Control
The position on my heater/AC control seems to be screwed up. I can set it for the AC to come out the dash vents and it works fine for a couple of minutes, but then the air flow seems to get directed elsewhere. I can turn the switch to defrost and after about a 5 second delay I can hear the door close in the duct work. When I switch it back to dash vent it works fine for another few minutes then goofs up again.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,119 Guests (See full list)
