4 Wheel Drive Not Working
How do you know they aren't spinning? Could be any number of things on a 2000. I have the same year and have a faulty 4x4 dash switch. This is very common, but if yours says it's in 4Hi on the dash yet still won't work it could be mechanical. Maybe in the transfer case?
Well i had my head out the window looking at the tires and the driver side didnt move, and i had people telling that the passenger side either. This has been a problem on and off for about 2 months now. The 4 wheel drive works when it wants to. i am wondering if it might be the front axle shift motor?
Basically, is the front drive shaft also spinning?
yes the drive shaft is turning.
if the propeller shaft is spinning, you have a diff problem
so would the front axle shift motor cause that if it's not engageing?
I wouldn't necessarily trust my friends to figure out whether my 4wd was working or not. With an open diff, the driver side could have been spinning when someone looked at the passenger side, and the passenger side could have been spinning when you looked at the driver side.
Try engaging 4wd on dry pavement and turning. If you have any binding, stop, and take it out of 4wd. Your 4wd works. If it doesn't bind, something's broken.
I have done that and it seem to be lockin thats why it has me puzzled. it almost seems like when it is engaged that there isnt enough torque being sent to the front. with haveing the friends looking at the passenger side, i was looking out the driver side at the same time.
    ballencd
    ballencd
  • Who's Online   5 Members, 1 Anonymous, 654 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
