2001 Chevy Silverado 5.3l 4wd Cylinder Head Torque Spec And Seqeunce
The bolts are TTY(Torque to Yield). If you over torque them, new ones are needed.
Torque All 11mm bolts torque to 22ft/lbs
All 11mm bolts turn and additional 90 degrees
Depending on year and bolt, measure the old bolts to see what size you need.
If you have 2 different length 11mm bolts 3.94" and 6.1"
Tighten 1-8 in sequence an additional 90 degrees
Tighten 9 and 10 an additional 50 degrees.
If you have all same length 11mm bolts 3.94"
Tighten 1-10 in sequence an additional 70 degrees.
Tighten all 8mm bolts #11-15 to 22ft/lbs.
