What's Zw7 Suspendion...i Want Overload Shocks..
randyf
I posted this in the full size truck forums, but didn't get any answers....any help?
I want to buy some overload - load leveling rear shocks for my 05 Suburban 1500. Monroe makes one to fit but it says not for Z55 or ZW7 suspensions.
What is my ZW7 suspension? Its not like the Z55 AutoRide.....I would think the shocks would be ok to use, am I right?
If Monroe states they won't work w/ the ZW7 suspension maybe you should be asking them why....I'm sure they have a technical support number located on their website.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
