Flow Chart Help
does anybody have the troubleshooting flow chart for a 2005 chevy crew cab rear windows. i have it narrowed down i think. i can jumper the connector at both rear doors and the window goes up and down but when i plug the switch in it doesnt work.
Also should the rear windows work from the drivers door without the rear window switches plugged in? thanks,Tim
Yes, you can order a Factory Service Manual set (4 books) for your specific year/model vehicle from a GM dealer. These would have flow charts and electrical diagrams for your specific vehicle in them. Show you exactly where things are located for testing. How to test at various points. And instructions for replacing faulty parts.
These days, with all the electronic and electrical "gizmos" in vehicles, a factory service manual set is just as important as other necessary tools.
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 371 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
