Converting Push-button 4wd To Manual
Has anyone else switched their push-button 4wd system (I have a 1997 K1500 with the three buttons for 2hi, 4hi, and 4lo) to the manual cable kit that sells for about $200? I'm having all kinds of problems with the push-button system and I'm tired of it. I just want my 4wd to work when I need it to. Any comments or suggestions appreciated.
