Will Denali/escalade 16" Fit 99-06 1500?
I've been looking to get some Denali/Escalade 16" rims for my 1999 Chevy Z71, and was wondering if these rims would fit. I talked to a guy one time that had a 95ish with the Denali 16" and he said he bought them from a guy that couldn't use them on his 99+ because the brake calipers rubbed.
I would think they would fit since they are basically the same setup.
they will fit. a neighbor of mine has em on his. your rims wont fit his, but his will fit yours. the brake caliper assembly too big on new ones.
  • 4 weeks later...
Wrong, I got my Denali rims, put new tires on them, balanced, and then tried to put them on and they hit the calipers. I tried grinding the calipers, which was successful, but still very little clearance. These were Denali wheels on an 99-00, which was the old body style. Unless I use spacers, there is not enough back spacing to fit them.
You also gotta remember that Denalis come with 4 wheel disc brakes which means the front rotors are a bit smaller than those with rear drums, so if you got rear drums you need at least 17" to clear without grinding.
I have a '99 new body style, which means I have 4 wheel disc. Unless I use spacers, there was no way they would fit without grinding. I'm not so fond of the idea of using spacers
Then the new ones probably have too much offset, the axles are a lot different on the NBS trucks (different track width)
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 309 Guests (See full list)
