Door Panel Removal
What do I have to take apart to get the driver's front door panel off from a LTZ Silverado? I remember seeing a thread about this in the past. Tried searching but couldn't find it. I don't think it was the LTZ trim anyways.
I had my door lock actuator replaced a couple weeks ago, and ever since then, my dome lights will not come on when I open the driver's door. They'll come on when any other door is opened, so I'm thinking the dealership forgot to plug something in or something? I just don't feel like making another appt. and driving in there, having someone pick me up, etc....
Another test before you pull the panel off is to roll down the driver's side door, get out, lock it, wait until the security light goes out, unlock the door with the knob, and open the door. If the alarm doesn't go off, then you are probably right about them not hooking something up. Unless of course they broke something.
Well, I tried what you said and the alarm went off. So what does that tell me?
Anyone know how to get the door panel off?
Odd, I would have thought the door position switch would trigger both the alarm and dome light. I don't know what's wrong. To get the door panel apart, this link should do it. http://www.gmfullsize.com/forum/showthread.php?t=93769
I was looking over the service manuals, I'm stumped. There is a door open and door ajar switch in the driver's door, not sure which would trigger the alarm and which would trigger the dome light. Hopefully someone can tell you what specifically to look at, otherwise you may have to check out those switches and see if the circuit is opening/closing like it's supposed to.
Thanks for the help. Hopefully the LTZ door panel will be simialar to the one shown in that link you gave me. Shouldn't be too big of a deal to get it off. I'm just gonna look for something unpluged. If nothing looks like it's unplugged, I'll probably just have to take it in again for something that wasn't wrong the first time. :smoker:
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
