Looking For Helpful Hints On New Truck Maintenance
I just purchased a 2009 Tahoe to replace my 97 Astro which died of cancer. I bought the van new in 96, if I had known to paint the fuel, brake, cooling, P/S, and A/C lines and lube a few other things, then I would probably still be driving it today.
On the new truck, what should I paint, lube, clean, and lookout for to make it last here in salty New England?
Is the any way to grease the ball joints? the only fittings I see are on the tie rod ends.
Which rubber parts should I spray with silicone each oil change? I typically do CV boots, A-Arm bushings, and door gaskets. (I should have done the body mounts on the 97!)
What do people use to lube the hinges, latches, or anything else on the chassis?
Thanks!
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
