Rear Axle Swap
Most likely not... I put a 3/4 rear end in my 99 K1500 OBS Z71... The rear end came out of a 97 3/4 ton Burb... I had to grind off all the leaf spring mount and shock mounts and re weld them in the proper locations... Once I got to the point of realizing they werent going to line up when I was trying my first attempt of installing the new rear it only took me about 2 hours to grind everything off and re weld... by the 3rd hour I was bleeding brake lines and driving the truck...
Just check out my build thread for the 14 sf rear end.. It will give you an idea of what I had to do... Who knows maybe it will line up I just want to forewarn you that it might not unless you measure it out or just line it up attempting to install it..
Gee Brian,You coulda' just got a rear-end from a 1/2-ton ext.cab with the "F44" Heavy-Duty Chassis package
(Since they use the 9.5",14-bolt,6-lug rear-end) It would have bolted right up :dunno:
Yeah, but the cheapest one that I could find on short notice was $500 and 500 miles away... This one cost next to nothing and came with money!!! haha Well not really. But it came with a 8 lug TSM Disc brake kit that I need to sell on ebay thats like NEW!!! New 4.10 gears and new axle shafts all of which I have to sell on ebay... haha
no. the 14bolt rear end that i put in my z71 came as a 8 lug but those axle shafts are interchangeable. but the only way to get 8 lug in the front is to do a sas (solid axle). and you would spend at least 8-10 grand easily with everything that would have to be specially made....
That is incorrect. On the new/older trucks, the 1500 will accept the 1500hd and the 2500 front hubs and brake disc, the 1500 will retain ALL parts including the caliper. The rear I do believe will be a swap with the exception of finding a shorter driveshaft, but I do not know this for sure.
better choose your 7000th carefully!!!
You are correct...
7000, Bitches.
I'm clocking out for the night to drink myself into celebratory submission. :thumbs:
While I am gone, feel free to bask in the glory of the Seventh Wrench. :cool:
Someone PM me if any new WeeMax/BedlinerBoy drama breaks out! :lol:
No. was responding to the 8 lug axle shafts for a 10 bolt rear end... Check out www.accuautoparts.com Thats where I got my ring&pinion rebuild kit and axle shafts to convert a hd 8 lug rear end to a 6 lug....
Now about the drive shaft I have no clue... my old drive shaft bolted up to the new hd rear end. I just had to make a universal joint...
I know for a fact that the hd 14bolt semi floater rear end will swap over... But sometimes you never know about perches and mounts until you are installing or measuring..
You are correct...
7000, Bitches.
I'm clocking out for the night to drink myself into celebratory submission. :D
While I am gone, feel free to bask in the glory of the Seventh Wrench. :D
From a "eyeball" prospective, it appears that the springs and shocks are mounted the same, but they could be different.
And as far as the fronts, I need a 8 lug 1500hd hub and brake disc.
    250.3k
    Wasierra1500
    Wasierra1500
  • Who's Online   1 Member, 0 Anonymous, 477 Guests (See full list)
