Best Leveling Kit
I want to get a leveling kit and ive been eyeing the readylift leveling kit, but i want to hear everyone elses oppinion on leveling kits. whats out there that i should be considering. i have a gmt900 z71 4x4
I don't have any experience with other leveling kits, but I installed the Rough Country 2" spacer on my truck yesterday. I am very happy with the results and the ride remained the same as stock. Looks like it should look from the factory. Installatin was easy with common hand tools and a couple jack stands. Took about an hour in the garage.
I'm still new at all this but after doing a good amount of research I ordered the Rancho Quick Lift set up Friday night. It's definitely more expensive but it really seemed to offer the most overall benefits at a reasonable price. Not only will it level the front end and allow you to go with larger tires, supposedly 35s, but it has suspension settings that you can change based upon the type of road you'll be driving on, which really appealed to me. There's some good discussion on the set up in these two posts.
http://www.gm-trucks.com/forums/index.php?showtopic=74427
http://www.gm-trucks.com/forums/index.php?...mp;#entry564476
If you do any kind of search at all or even just look at the first page of topics then you can find more than enough information on this. The majority of the forum uses Rough Country 2" level. Great design as well as easiest installation. Others go with CCM 2.5" as well as other brands. I'm running RC 2" and love it. There are plenty of options out there. Just do a little searching
Mines a 2005 but I'm runnin a RC kit as well. Love it, no adverse effects on ride or anything else so far. Have logged around 40,000 miles since installing it. Also installed the RC Nitro 9000 shocks to go along with it in the front and those are good as well.
i wanted to go ccm 2.5" kit but i came on a deal on a RC 2" kit for $50 shipped so i have it and love it :P
I'm pretty sure with the Rancho Quicklift on the GMT900, the biggest you can go is 33". I think the Ford's with the Quicklift can go 35"...
  • 1 month later...
I am new the truck scene so I also have some question. I'm looking for a leveling kit. I was pretty set on the rough country 2" because many people on the forum seems to like it. I called the local offroad place and for the GMC they recommend the readylift kit which is like 2.25" because it puts less stress with having something on the top and bottom of the suspension.
RC 2" $64.95
Readylift 2.25 $229.95
labor: 270 + 89.95 alignment
What do you guys think? I'm not fimiliar much with trucks but there is a HUGE price difference between the 2 leveling kits. Thanks.
RC 2" $64.95
Just get the RC kit.. its just a leveling kit, no need to make it out to be more than it is.
And what is the max size tire I can go with the RC kit? (I have the OEM 20" rims, currently with 275/55/R20)
I went with the readylift 2.25. Quick install and no issues so far. Luckily you're doing your research, I never did hence the readylift. At the end of the day it's just a leveling kit so your budget will decide for you.
They all r just as good as tbe other. I just went with easyest install and cheapest. I do wish mine was around 1/4" more now but i paid $40 shipped for mine. It will work till 6" lift.
I just installed the Rancho Quicklift in my 07 silverado and it looks awesome. I pulled the struts out myself and had a shop swap the springs, so besides the parts its 170 with an alignment and swapping the springs. On a side note the front suspension handles awesome! It was worth the money!
    250.3k
    user087
    user087
  • Who's Online   5 Members, 0 Anonymous, 987 Guests (See full list)
    • Thanks @newdude, guess I'll keep looking.  Test driving so many trucks that have obvious things broken, I'm thinking "if they couldn't even be bothered to fix the power seat," what else is broken".   Just drove a 2021 where the power seat motor was grinding/binding and wouldn't do anything but make a terrible sound.   An owner that puts dents on the bumper, doesn't fix a seat motor, and had spotty service intervals (along with missing major services) doesn't give me the best of confidence.   Amazed at the number of people that will finance a $60k+ truck, run it into the ground, then trade with a loan balance (every single one had "loan/lien reported" on the CARFAX at the last year of registration).
    • Not true! I have been runing them since 2006 F250! suspension component that works as a sway bar, a traction bar, and a helper spring points directly to the RoadActive Suspension (RAS) kit. Works as a sway bar, a traction bar, and a helper spring.
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
