There's a new Suburban sitting in my driveway
It's a 2001 K1500 Z71.
Should I get the Gale Banks Power Pack:
http://galebanks.com/product_images/SC12A_PowerPack.jpg
Anybody have that?  How much louder is it?  I want to keep it quiet.
What sort of transmission mods are available? Something to make it shift a bit firmer and prolong the life of the tranny?
How about this:
http://truckperformance.com/display.image....57-3021_500.jpg
What chips are available?  I know there's a Jet chip and Hypertech Power Programmer.  What else is there?
Also, how often do the plugs need to be changed?  Does this engine use those 100,000-mile plugs?  Or "regular" plugs?  How difficult is it to change them?
What other forums exist for Suburban owners?
If it's a new suburban it's got the long life plugs.  If you want firmer shifting and more power go with a Hypertech Power Programmer.  The banks power pack is just several components all sent as a package.  There are several different exhaust set ups you can get.  I'd go with a flowmaster personally.  For 40 bucks you can get a k&n drop in filter for some added power.  go to www.truckperformance.com I'm sure you'll find a lot of stuff.  Any more questions feel free to ask and welcome to the forum.
Quote from g6t6o, posted on Sep. 28 2001,1:41
Hey are you from ls1.com?  Your name looks really familar!!:(
Josh
I've been there a few times.  I mainly post on the Corral and TurboBuick.com now.  Not much happening on this board.  Are there any other boards with more traffic for us Suburban owners?
Another question: Where is the sticker located that shows what all option codes are installed in a Suburban?
Here's the oficial GM low-down on your 5.3L.
http://www.gm.com/automot....ain.htm
A hyper Tech Programmer will adjust shift points/firmness/engine power curve/speedo etc...  They are about $300 (I think).
Welcome to the forum and keep on asking questions...  we'll try our hardest to help you out.
lyonsd,
Welcome and Congrats on the new Sub!  As you already know there are great people here at this site that contribute good info.  While this site is very good, the link below will take you to the updated "Suburban site".  Since I have 2 Subs and 1 pickup I spend about twice as much time over there ;) and find the folks very helpful over the last 3+ years or so.  Here is the link:
http://forums.vmag.com/suvsuburban0801/
See you there,
BIG BLUE
P.S.  Also, you will find the following link to a web site designed by a guy named "#1 Son"  He is a regular at the Sub forum that took the time and effort to store many archived posts from the Sub board (since the search function doesn't work so well).  There is 3+ years of info at his site, just about anything you would want to know.  Here it is:
http://subtopics.freeyellow.com/subtopics.htm
I noticed on the Duramax-equipped trucks, there's a transmission temperature gauge under the "Message Center" in the dash.  On my Suburban there's nothing there, but the gauge cut-out.
If I were to add a supercharger, is there a decent boost gauge available that will fit in that location and look "factory"?
I believe the transmission temperature gauge is included with the 6.0, 8.1 and duramax engines. The smaller engines do not include it even though it would probably be most useful on them.
    • Did the KYBs keep it the same height in the front? I was concerned that pre-assembled assembly would raise it up an inch to standard non-z60 height.. I guess which it would make the rake 1 inch instead of 2 inches.
    • Thank you for keeping the train on the tracks and for a thoughtful engagement. I enjoyed the reflection on a previous stance to refine and improve your position. I like that inquisitive flexibility about you Atlas.    No the process isn't sterile. Hundreds, perhaps thousands of miles of piping, vessels, pumps. Chevron, the people I worked for, were keenly aware that there is a market for what is known as their "ISOCLEAN" line of lubricants. These are lubricants that are the same as those sold bulk that are further processed by filtration to a level your particular application demands. They will filter and package and provide lab documentation as required. Do not kid yourself. Every gallon of oil that goes into a Chevron Turbine, reciprocating compressor, generator is prefiltered and tested before being charged. Lest wise it was when I was there in the plants I worked in.    There are requirements set by manufactures for the cleanliness of the oils used in their equipment. OTR such as CUMMINS has standards shared with customers on this. Commercial interest selling to Ma and Pa do, but don't share that information. Not even upon request but internally, they do exist.    The GM study sited, (Graph from Machinery Lubrication in previous post) only shows "relative" importance.  I find that fascinating. By constructing the graph like this they admit there are dozens of factors in engine life and via scientific method determined the effect of 'relative cleanliness' on engine life not in miles but in 'FACTORS'. This allows a certain amount of reverse engineering does it not?   They even provided some touchstones. Beta 75 as a reference point. Wonderful stuff!!   Smaller blenders CAN and some DO take the time and effort to do better than a refinery or large bulk blender, like Warren Oil, in improving the "in the can" cleanliness. No I don't have a list but testing could generate that information.    Again, but one of several levers we can pull to improve engine life. The simplest is keeping a clean work station while doing your own oil changes.
    • Thank you. I'll give it a try
    • I just spent the last 45K miles doing samples every oil change over more than a full year to get the data for seasons and break-in to broke in.    I found the same thing to be true. Something was always teetering on done or had stepped off the cliff long before the OLM was DOA. In fact, I found about a thousand mile difference between summer and winter. That is during the winter half the OLM was STILL too long. Even the severe schedule was to long in the winter.   Now having done the work I can say I was NOT DISAPOINTED. I saw nothing I didn't already know. Nothing my father hadn't already demonstrated in his 2K OCI's pushing dated iron on dated oils and weak filters to mileages well beyond 300K.   Building on his work through use of Lab testing it wasn't hard to find the correlation between 'sight/feel/odor, the things dad relied on, and test results. Use of current viscosity stable chemistries & filters has pushed that marker for my motors out to 3K summer, 4K winter.    So the early lies were 3K on conventional oil and the lie upon the lie was 7K+. turns out to be off by a factor of two.    So... it is true that modern chemistry has doubled the useful oil life. But the base milage that came from was off by double. It's how good lies work. Partly true, sometimes mostly true so that your meter isn't set off. It also means that non-shear-stable shelf oils are only now as good as the old oils were in their best case scenario.    So the question now is how do we improve on that? Thus the question into cleanliness among the other items listed in the post quoted below.    If this bores you, feel free not to participate.
    • Is it though?  Like LTZ, not a high take rate.  Current Sierra has AT4, Denali and Elevation as its main bread winners.  Each trim accounting for 25-35% of sales for Sierra.  SLT makes up about 10-15% at best.        Like others have predicted here for GMC, it will be:   - Pro (equal to WT Chevy)   - Elevation (replaces SLE and SLT)   - AT4 (and X)   - Denali (and Ultimate).
