Rpm's stick at 2000/80 kph
04-silver
I originally posted this under"gas engines" I did get some help/advice from one member but the more info the better........lol
This is what happens: (the RPM and K numbers are relatively close but not 100%)
Truck shifts fine, 22-2500@30k's, 22-2500@60k's. When I continue to increase to 80kph the RPMs hit 2500 and drop to 18-2000RPM, same as before except now when I accelerate from 80 kph the RPMs will not budge from 18-2000 and I do get a slight grinding feeling from the gas pedal, I will get the truck up to about 105/110 kph before the RPM's eventually jump to 25-2800. Its almost like the it sits in a lock postion.
The only other way I can get the RPM's to increase is to either punch on it and the RPM's scoot to 3500-4000 or I can take my foot off the pedal for a split second and re-apply.
This will happen in D, 3, w/wo auto, w/wo tow haul doesn't matter will always stick at 1800 and 80 kph when gradually accelerating.
This does not happen if I accelerate fast as in from an on-ramp.
:flag:
John
I'm not sure what you're saying here. Is it that the engine rpm's go up, but the tach doesn't move, the rpm's don't go up, or the TCC doesn't come out of lockup?
All I'm going by here is what I see on the tach and the speedometer.
When the tach diplays 2000 rpm and the truck is travel at a steady speed of 80 kph this is where the rpms on the tach seem to stick. From this point I will gradually increase the speed from 80 klm to about 110 klms, during this acceleration period the tach has/will not move from 2000, untill the truck is doing approximetly 111kph then the tach jumps to 2500/2800.
edit-unless
I just going by the gauges the tach and speedo, there does seem to be a slight grinding feel during this period.
:flag:
john
edit-unless
:flag:
john
For what it's worth, I've got the exact same condition in my 99 Blazer. I was a little worried when I first noticed in in December 2003, but since then I've come to ignore it. I have the a cabled throttle, so it's not that like someone else had mentioned. I cleaned out the throttle as well, that didn't make a difference.
If you find a solution, let us know, as I'm quite curious! I'm planning on selling my blazer in the next month, but I'd still like to know for curiosity's sake!
Cameron
Well thanks for the info.
I just had the truck in for its yearly about 2 months ago and they/mechanic told me the truck has all the updates. Guess I'll just wait untill the truck's 18th month check up and see what happens by then. Still have 2 years left on the warranty and this clitch is noted on the mechanic's work order. When I find fix or whatever I will let you know.
From my other post one member told me possibly the program maybe corrupt in the PCM and or the VSS (vehicle speed senor)
Previous post
:D
John
GM doesn't use Windows and I have never heard of the program being corrupt. :D And the VSS has nothing to do with the tach. VSS is vehicle speed, not engine speed.
:cool:
Initially it sounded good to me, I guess I let it slip that mechanic is not my profession :cool:
Thanks GM-Tech
:D
John
Edit-in all fairness this is his whole quote
It's the torque converter clutch locking when you see the rpm's drop to 2000. Why it doesn't go up from there is a good question. Sounds like a VSS (vehicle speed sensor) problem to me, or some corruption in the PCM program. The dealer only sees that the program is there and functioning. It cannot see if the program is corrupted if no codes are being set
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
