FS: Bohmen 5000k Diamond White HID kit
SoCalChris
This kit is a direct replacement for 9006 bulbs, which is the low beam for NBS trucks. No splicing required, it is plug & play. Send me a PM if you want one in a different bulb, or different temperature.
BOHMEN H.I.D. 5000K Retrofit Conversion Kit ( Diamond White)
* A 35W HID, up to 3~4 x the lumens at the source compared to a 55W halogen bulbs
* Capsule aligned to the original bulb filament, and the original beam pattern is not altered.
* Exact size and fitting to your OEM halogen bulb. 100% Reversable.
* 5" silicone coated wires with Silicone rubber grommet for an additional seal.
* AMP waterproof sealed connectors.
* Fully sealed. Full function between DC 12V/24V (9-32 volts).
* World Smallest size (2.75" x 2.75" x 1.25") & weather resistant Ballast.
* Extra long 20" wiring harness to igniter, 24" wiring harness to your power source.
* Sealed compact Igniter with Intel Pentium chip set. Three stage auto safety features prevent Ballast overload due to high heat, power spike.
* Silicone sealed wiring harness Precision manufacturing ensures straight vertical alignment.
* Exact size and fitting to your OEM power source. Polarity insensitive, therefore you can not "fry" the Ballast. Full-proof positive (+) & negative (-) specific connection.
* Highest German Industry Standard OEM quality D2 HID Bulb, UV cut class with AMP sealed protection system, up to 3200 hours
* 6 Months Replaceable Manufacture Warranty on all parts.
    250.3k
    pimafe6931
    pimafe6931
  • Who's Online   4 Members, 0 Anonymous, 952 Guests (See full list)
