2007 SLE DIC Upgrade
I just wanted to let everyone know that adding the Driver Information Center (DIC) to your 2007 SLE is a snap.
I ordered the part from gmpartsdirect.com. The install took 5 minutes.
Directions (I would have taken photos but it's really unnecessary as this is so simple.)
1. Turn the truck off.
2. Pull the old section of dash (on the left of the wheel) off by hand.
3. Remove the light controls (simple plastic clips).
4. Remove the extra cable clipped into the piece of dash (it's already there just not being used...YET!
5. Install the light controls into the new piece of dash (yes it comes with the new piece of dash, new vent and the switch)
6. Plug the previously non used wire into the new switch.
7. Put the new dash plate back into place by hand.
8. Turn on the truck! You're done!
This mod gives you access to fuel mileage, range, gallons used, V8/V4 mode notification, tire pressures, tire sensor learning, key fob learning, chime volume, entry and exit lighting schemes, lock and unlock schemes (including automatic lock/unlock), unit and language choices, engine hours and probably more that I have forgotten already.
The beauty of all of this is the cost - $100.22 shipped.
Enjoy.
If you have questions, let me know!
Daddy. :confused:
  • Replies 663
What happens to the standard trip-odometer type basic DIC controller? Does it still work? Can you order that panel in ebony black? I'm VERY interested! I assume all the wiring is already there? I'd like to see your finnished product.
What happens to the standard trip-odometer type basic DIC controller? Does it still work? Can you order that panel in ebony black? I'm VERY interested! I assume all the wiring is already there? I'd like to see your finished product.
I honestly haven't tried to use the original button for the original information but you get all of that through the new one. You lose no functionality whatsoever. The part I linked to is black, I have the full black interior and this is an OEM part. I can send you pics of the finished install but it looks just like the one in this link:
http://www.automobilemag.com/features/news...a/photo_03.html
It's just above and to the right of the light switch and just to the right of the vent.
Daddy.
Can you try the factory switch and see what it does? I would like to see your install. Then I can see exactly what mine would look like.
Thanks!
Thanks!
The old switch toggles between the trip odometer and the regular odometer, it appears that the tranny temp has moved over to the new switch.
I'll try and take some pics in a few minutes and post them although it won't look any different than the link I sent before.
Daddy.
Here are the pics. As I explained, it is very simple to do this as evident by the fact that I basically just did it again in order to take these pics.
This is the old piece of dash.
The red arrow shows the cable that is already there now attached to the switch.
Now for the new piece with the switch installed.
There are many more screens but here's a shot of the way the display is now used.
I hope this is enough to get the point across.
Did I mention that the switch is also back-lit to match everything else in the truck when the lights are on?
Daddy
Is there a cheaper place to buy these? Did you have to reset the tire pressure monitor?
I don't mean to sound rude but I don't think I could be any more clear that the entire upgrade took 5 minutes and nothing more than what I have explained. However, just for clarification's sake, no, I did not have to reset the tire pressure sensors or anything else for that matter.
If you want to search for it cheaper, feel free. To the best I was able to find them, this was the cheapest option. It's $100 for something that would have cost you much more to have on your truck from the dealer.
Daddy.
Help me understand something. What package did you buy that has a DIC without control switches? I just ordered a truck on Monday and I don't wan't this little detail overlooked.
I have a SLE1 3SA with some additional options.
It shows on the GMC site that the DIC is standard but I believe that is referring to the limited use version that only gives odometer, trip odometer and tranny temp that i had prior to this upgrade. You'll probably need to ask the dealer to be certain.
Daddy.
If you order the preferred package on Sierra SLE1 or convenience package on LT1 you should get the full DIC with contol switches to left of steering wheel.
That makes sense, I suppose. I got the convenience package but not the preferred.
Daddy
  • 4 weeks later...
Wow, thanks for this post! I've been searching all over trying to find a way to add the DIC to my 2007 Silverado LT.
A quick question though, is the dash plate the same for both the Sierra and the Silverado? Meaning, will the part linked to work for both?
Thanks!
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,642 Guests (See full list)
    • I’m definitely interested to hear the end result here.
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
