2007 SLE DIC Upgrade
Thats an awesome mod! I'm ording the parts for my 07 NBS SLE Sierra. Thanks daddy I can't wait to see my Mileage, Tire pressure and all the other info
Then again...you may not want to see your mileage. :tear:
Isn't that the truth? :confused:
  • Replies 663
Just ordered mine from the dealer. $95 Cdn
Do you pull the old switch off starting from the top left? I'm scared to break it.
Thanks for all the great info daddy!
If you are referring to the old bezel, yes. As long as you don't yank, and simply pull, you'll be fine. Mine have been on and off a number of times already with no problem. You'll be replacing your entire bezel anyway so if you break it, oh well.
Daddy.
  • 3 weeks later...
great find!!!!!!!!! I have a SLE2 so I don't need to do the mod, but had I know this I would have bought the 3/4 ton crew cab I was looking at, instead of the 1/2 ton with it, I didnt know it was this easy to add this function.
I just wanted to let everyone know that adding the Driver Information Center (DIC) to your 2007 SLE is a snap.
I ordered the part from gmpartsdirect.com. The install took 5 minutes.
Directions (I would have taken photos but it's really unnecessary as this is so simple.)
1. Turn the truck off.
2. Pull the old section of dash (on the left of the wheel) off by hand.
3. Remove the light controls (simple plastic clips).
4. Remove the extra cable clipped into the piece of dash (it's already there just not being used...YET!
5. Install the light controls into the new piece of dash (yes it comes with the new piece of dash, new vent and the switch)
6. Plug the previously non used wire into the new switch.
7. Put the new dash plate back into place by hand.
8. Turn on the truck! You're done!
This mod gives you access to fuel mileage, range, gallons used, V8/V4 mode notification, tire pressures, tire sensor learning, key fob learning, chime volume, entry and exit lighting schemes, lock and unlock schemes (including automatic lock/unlock), unit and language choices, engine hours and probably more that I have forgotten already.
The beauty of all of this is the cost - $100.22 shipped.
Enjoy.
If you have questions, let me know!
Daddy. :thumbs:
Daddy,
Thanks a ton for the post! That's a killer upgrade.
Also thanks to Slaphappy for the Chevy link (http://chevroletpartspeople.com/searchprod...ormation+Switch). I ordered the part from them last weekend. It hasn't shipped yet, but hopefully I'll get it soon. Which trim Silverado do you have?
  • 3 weeks later...
Daddy,
Glad it helped you.
Daddy.
Daddy and Slaphappy,
I finally received my DIC switch! I'm hoping to get out there in the morning to install it.
Question:
Did y'all follow the instructions that are provided with the switch (19 steps-- removing the knee bolster, parking brake release handle etc...) or did you simply yank the old panel piece off?
Also, any recommendations for removing the old piece? Should I be prying the old panel (with a screwdriver or something similar) or just pull the panel off?
Thanks for the help.
John
No offense, but whoever at GM came up with the "DIC" acronym, must have been a real DIC.
I decided to just pull on the panel until it popped off. That worked out fine.
Anyway, the switch is in and I'm loving it. Well, all except for seeing the instant mileage when driving up hills.
Thanks again for the information and help. I wish all upgrades were this easy.
Great upgrade! Now then, do you know how to add the rainsense wiper control system?
I'm going to order the DIC from the dealer tomorrow.Should have it in a day or 2.
Daddy,where did you get the chrome door handles,I can only find the covers?Are they for a Denali?
Sorry for the delay. I am on vacation and not checking in that often right now but I am going to try to respond to all the recent posts at once here.
Here we go:
Just did this to my Chevy. Thanks for the info. It made the decision for me and it worked out great!
Friggin' Sweet.
I see you got your answer, congrats on the best upgrade for the money!
Not sure but I think that'll be a real PITA.
gmpartsdirect.com part number 19159770
Take Care,
Daddy
Dealer had the DIC in stock.I installed it this morning in a blink.Average MPG is 14.6,mostly city,hopefully this will improve when I switch to Amsoil.Thanks for the information Daddy.
No Problem! That's what makes this site great. Now, if someone can show me how to make make my 17 inches grow into 20's we'll be all set. :fume:
Daddy
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
    • Great video. I almost want to reserve one now.
    • I traced the atf cooling system in my 1500 and it comes out of the transmission, into the bar/plate liquid/liquid heat exchanger, as stated above.  Then it crosses over to the external thermostat/bypass and then  to the aux cooler in front of the main radiator.  Hence, on this routing, the PPE thermostat bypass eliminator is an $85 piece of bling that does nothing for reducing atf temps on this truck.  I think I'll temporarily clamp a needle nose vise grip on the coolant feed hose to the bar/plate cooler and see how much the atf temp drops.  With the use of ULV trans fluid, I'm not convinced running the trans cooler than OEM spec is going to be detrimental to the life of the transmission.    I found this interesting on the Dana/Long site stating that they make transmission cooling/heating bar plate heat exchangers.  I worked with Dana/Long on a few projects when I was at the gas powered fun factory. https://www.dana.co.jp/downloads/PTG/Long/Dana_TOC_SpecSht.pdf  Bar plate heat exchangers are just a stack of stamped parallel path fluid channels, assembled and vacuum furnace brazed to make the final assembly.  Want more cooling/heating, just stack more plates until you run out of package space.   Anyway, thanks for the info, much appreciated.
