Project Rear End Commences!
Well guys I am finally ordering everything that I need to finish this project of mine tonight! (I am ordering tonight, not finishing the project. But I wish it was done.)
I have a 14 Bolt sf w/ gov lok, 4.10 gears, and TSM disc brake conversion 8 lug. I am going to build it into a 3.73, 6 lug, with a disc brake conversion kit but prolly not tsm. I am trying to save a little money cause the wife and I just bought a house.
But anyways, I will post pictures of my progress. Any helps couldnt hurt. After I do some price checking and ordering I will show you pictures of my purchases.
Here is the Disc brake Conversion kit that I am going to get! I would have ordered it tonight over the website but the big red letters that were going across the screen saying: "Make your credit card purchases online at your own risk" really wanted to make me call it in tomorrow!
Here is the link: Click this!
I am ordering the mounting kit and calipers without the emergency brake. I couldnt justify paying an additional $200 just for emergency brake calipers that arent even going to work half as good as drum brakes!
I may order them later though...
The gears have to match front and rear or you will blow your transfer case in a minute!
I don't think he knew you had 3.73s. Is it finished yet? Are you slacking on us? Huh Huh Huh? :D
I am going to show my ignorance here.
Is the whole "blowing your transfer case out" thing something that only happens if i engage 4wd?
In other words, if I change out just the rear gears, and call it a day, then go out and drive will my driving in 2wd blow my transfer case, or will I only blow it if I engage 4WD?
I believe this requires a scientific study to be answered correctly. Please try it and post your results! :D
haha I could have installed this rear end in my truck as is if I never intended on using my 4wd again. I have heard 2 things about the using 4wd with different gear ratios...
I heard that if you are offroad that you can run different gear ratios....
But I rather believe in:
If you run your 4wd with different gear ratio's your transfer case will blow within a minute!
Eureka!!!
Disc Brake Conversion kit arrived today! Disc Brake Conversion kit arrived today! Disc Brake Conversion kit arrived today!
Ok I am a little excited!
Here is the pictures of the kit. I am going to the shop tonight and taking back the calipers to switch for some calipers for with parking brake!
If you know anyone doing this dont buy the caliper through TSM they are a rip off! I bought mine from advanced and they are the same ones that he uses. I saved about $70 and I purchased $30 pads! The calipers without parking brake was $11.88ea at advanced auto parts.
I will let you know how much the new calipers cost after a take these ones back!
Oh and I will get a bunch of pictures to update my progress! Ring gear and pinion gear starting tomorrow!
Eureka!!!
Damn. How long did that take you? lol
lol
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
    • I’m definitely interested to hear the end result here.
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
