Rear End Gear Indentification
Can anyone tell me how to identify my rear gear ratio on my 94 c1500? I had a rock go through my radiator and destroy my fan shroud. and to order a replacement shroud I need the rear gear ratio. why I don't know but that's what i am told.
After doing some research I see that the code should be on my parts identification sticker in my glove box beginning with G. the only g i see on this sticker is GU4, can anyone tell me the gear ratio from this code?
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
