No Power To Passenger Side Door
I HAVE NO POWE GOING TO MY PASSENGER SIDE DOOR. THE MIRROR, LOCK AND WINDOW WILL NOT OPERATE. I CHECKED ALL THE FUSES, I SWITCHED THE RELAYS AND STLL NOTHING. WHEN I OPEN THE PASSENGER DOOR THE INTERIOR LIGHTS DO NOT COME ON! THANKS
Make sure to check the 50 amp fuse in engine area fuse block. it feeds the relays.check the power at the window relays to ground,you should have power on one of the pins were the relay plugs into.mine ended up being bad wire blowing the 50amp fues were it comes into the fuseblock under dash were relays are.my foot hadbroken them by wear over time.
    Jmuck1
    Jmuck1
  • Who's Online   4 Members, 0 Anonymous, 761 Guests (See full list)
