Dic Silverado
manalexcrazy
I have a 2007 silverado classic crew cab lt1, i was wondering if it was possible to changemy current dic which showes odom, trip, engin hrs, to a DIC that shows gas milage oil life ect,.
i need to know does my truck have the necessary stuff andall i need is the steering wheel to run it or do i need more please help
i see how they did that but i have a silverado classic itis the 06 body style the dic controls would be on the steering wheel in my body style so dose that mean i have to buy a steering wheel and thats it ??
I have an 06 Sierra CC that didn't have the extra stuff on the DIC from the factory. It requires a new "clock spring" or steering harness, a new steering wheel with the buttons on it, and a trip to a dealer that can pull their head out of their ass to actually try to reprogram the truck. It CAN be done, the project took a LONG TIME for me because of funds. The clock spring is the most expensive part.
I love it, I got a few extra cool features out of it, like the curb feature that tilts both or just one (your choice) side mirrors when the truck is placed in reverse.
Very nice addition to my truck! Good luck!
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 463 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
