Wanted - Tow Hooks
I need the same thing. Anybody have another set they're willing to let go of cheap?
I have a set that are black. They fit the Silverado and Sierra. They are worth $80... I will sell them for $65/OBO. The package will include mounting hardware as well. Please email me at: [email protected] with your shipping info for a detailed invoice. Thanks!!
:lol:
