3.42 Rear Axle Ratio
i have an 03 sierra 4.8l with a 3.42 rear ratio.
not to impressed with it on the highway though for power.
is there anything i can do to get more performance?
thanks
Have a tune done on it. Look into all the Black Bear customers that are satisfied. You could also got to a different gearing. I'd start with a tune.
    bellssn690
    bellssn690
  • Who's Online   6 Members, 0 Anonymous, 579 Guests (See full list)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
