Usa Spec Pa11 Install
Hey everyone. Finally on the 'finishing' stages of my truck before i drive it, but started tonight hooking up my usa spec ipod adapter on my 03 Silverado. Hooked it up to and ipod touch to verify it works, and it does :lol:. But should i try to mount the little white box (unit) behind the stereo?, as there is plenty of room and cable. Or should i just lay the white unit in the glove box? Then make a nice piece of wood or something to screw it into and hold it nicely? What have you guys done?
Also, i see there are 4 dipswitches on the side of the unit, what are they for? Do any of those control if the song title shows up on my radio? I hope they do, but i have my doubts, but if the song title did, that would be sweet!
Any help is appreciated...thanks Ryan!
Haven't used USAspec in the truck, by did in a Honda.
The dipswitches change the manner in which you can control the iPod...via the Radio only or via the Ipod controls, both, etc.
I usually just zip tie the white box to something sturdy behind the radio. If it might rub, I'll wrap it in some foam tape. Good to go.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,283 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
