Nav Radio Question
Doogie
I purchased a Nav radio out of a Torrent for a Equinox and it is not functioning properly. Anyone know how to temporally disable the theft lock like in the older body style trucks? I could pull the fuse for the radio and put it back in and it would work until the truck was started or turned off then back on.
I also wasn't expecting the back lighting on the radio to be red. Anyway to change that to the green to match everything else?
Thanks
Doogie
Also does anyone know of someone who is experienced at reprogramming these radios? IE different software. When the radio powers up it shows the Pontiac symbol. I would rather the Chevy logo.
Thanks I got my fingers crossed that this site comes through for me.
Doogie
There is nothing you can do about the red backlighting because your nav unit came from a Pontiac. The part numbers would be completely different. I would assume (I could be wrong) that your Pontiac symbol on startup could be changed by a trip to the dealer to get it programmed. That unit probably still has the VIN number from the previous car it was installed into. It's not a do it yourself job unless you own a Tech 2.
There is a small chance the Torrent and Equinox nav units aren't even compatible with each other. They may be physically the same size, but that doesn't mean they work sometimes. The Acadia units are incompatible with any of the GMT-900 trucks for example.
I am no expert though. Hopefully someone on here may know or talk to your dealer.
Yea, I hope that it is not incompatible with my Equinox. That would be very disappointing.
I am doing research on updating my '07 Sierra to Nav. There is an insane amount of part numbers out there and several manufacturers of these Nav units (Denso and Delphi). easy to get confused if you do it yourself.
Hope your unit works!
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,180 Guests (See full list)
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
