Loud Knock From Diff!
hey guys i got a 2000 gmc sierra 1500 2wd with the 5.3l. the other day i was driving when a women had cut me off so i had to get on my brakes hard and after that moment my truck started to make a loud knock whenever i was turning.Howerever at the shop i work in we had a similiar problem with a silverado and it turned out to be his differential.after checking it a few times i can see that the rear axles are like jumpin it looks and sounds really bad. i was wondering if its worth the rebuild or should i swap it.i understand tho that swapping it is a very risky move. I love my truck and baby it dont understand why it happened??i also wanted to change my gear ratio to a 4.10.i believe i have the 3.43 er sumtin like that... what do you guys think??
Does yours have the G-80 Locking Diff? (I know you said 2WD, however I am not sure if the G-80 was available as an option on 2WD trucks back then)
If so, more then likely it went Kablooey! Pull the pumpkin cover off and take a looksie inside.
I dont believe so would i find that info in the glove box? but i do think sumtin jus went "kablooey" in there lol should i just get a rebuild kit and rebuild it with the new gear ratio?
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
