Lower Leveling Kit Install
has any one installed the RC under strut leveling kit without taking the lower ball joint,
tie rod bar and stabilizer bar apart. Is there an easier way of doing it?
any tricks to installing?
I only want to lift the front 1 to 1.5 inches.
I have an 09 GMC 1500 4X4.
thanks for any advice.
I have installed this kit and I only disconnected the sway bar end link. And that was it. Did it twice this way with no issues.
Same here.
Same here.
thanks for the reply, sound like it should be fairly simple.
thanks
Same here.
thanks
It is fairly simple, I did mine by myself.
Same here.
thanks
Done, disconnected the sway bar and also had to loosen the uppper strut bolts, everything went well, took me alittle longer on the 1st side I did, but the other side went very smooth, thanks everyone for the information.
  • 3 weeks later...
Did mine today by only removing the wheels and the sway bar bolts.
Since I didn't mess with anything else, do I still need to have an alignment done. It drives the same and doesn't pull to either side.
