Interior Squeek Noise
I have a 2009 2500 hd Crew Cab with 4500 miles on it. I have a noise in the interior. it sounds like the rubber is squeeking against the doors. Does any one have any suggestions on this problem.
The dealer actually replaced the door seals? That's interesting...
I took mine in for sqeeking doors about 2 months after I bought it and they put on some kind of "dry silicone" lube that worked for about a day. Since then, I've taken to smearing on some liquid silicone oil all over the rubber once every six months or so. It's the only thing that's worked so far. My '05 had squeeky doors and my Dad's '07 2500 crew cab does it worse than mine. I think it's just one of those GM things we have to tolerate.
The dealer in California tried that dry silicon lube twice then just replaced them because they seen it wasnt working. It is worth a try being that it is still under warranty. Just keep going back for the same issue and they will change them eventually I would hope.
My 09 Sierra ECSB with 1000 miles squeeks and rattles also. It was quiet when I first picked it up, the more miles, the louder it gets. Haven't brought it back to the dealership yet, but not sure they'll do anything.
I also have the ECSB body. The dealer first adjusted the doors then the dry lube and finally replaced the seals. I notice if I do not shut the rear doors good then it will make noise butonly if the rear doors are not shut correctly. The dealer should work with you on it.
My 09 Silverado ECSB also had that issue, but it occurred a few months after I got the truck. I simply got a spray can of silicon lube and applied it generously to all door seals - the noises stopped. I'll keep watch over this to see if it reoccurs again in 6 months
Just to add another idea: I also have a squeak in my interior when going over rough pavement. Had it pretty much since brand new.
I noticed that if I push my elbow into the interior driver door panel just below the glass toward the back of the door, the sound stops. The panel is not tight enough and squeaks whenever it rubs against whatever surface is behind/beside it. I'm slowly getting used to ignoring it.
Maybe this is the same issue you guys are talking about?
Yeah, it's the same squeaking door noise that alot of people are complaining about. Really just an annoyance more than anything and only at slow speeds around town. Silicone lube can help, but it always comes back to some degree.
As soon as you hit highway speeds, all's quiet. It's a function of cabin pressure...At highway speed, there is sufficient air pressure being forced into the cab by vehicle speed and it holds everything tighter...At least that's my take on it. Anyone else???
Sounds like it makes sense, this is the exact thing mine does (and many others I assume).
Yup, I've just chalked it up to an annoyance as well. Just to add to your cabin pressure idea, the inside should theoretically have a higher pressure (like you stated) since the outside air rushing around the outside of the vehicle body at high velocity would be lower pressure. Grumpy Aero Guy could probably clarify this better.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
