Chevy Transmission Lines Rusted
I have an 88 305 standard cab 4wd pu.
The cooler lines are rusting through. Does anybody know the specs on these lines?
Size, fitting size, length? I figure I am going to have to bend them from straight pipe?
Thinking about making each line into two segments to make the install a little easier(working on the ground as usual)
Thanks in advance for any feedback on this.
This place has them in o.e. steel or stainless.....all you have to do is install them.
http://www.classictube.com/index.asp
Many thanks, that sounds like a great source and will probably save me a lot of frustration and aggravation which I can use when taking off the old lines!
    BakNBlk
    BakNBlk
  • Who's Online   2 Members, 0 Anonymous, 542 Guests (See full list)
