Roof Buckling Noise
I installed a small cab over camper on my 04 ext cab 2500hd it comes over the cab half way. there is about 8 inches from truck roof to underside camper. when I meet on coming commercial trucks or high winds the center of my cab buckels in and makes a very loud noise. is this normal or should the roof be fastened some how? I can push down on center of roof and make the same sound,is there adhesive broken loose inside etc. I notice on crew cab trucks there are ribs formed on top of roof to give strength? any ideas!
With a prior roof strobe mount I used to have it used to cause my roof to make alot of noises on the highway. A few years ago I bought a new strobe mount, and this one allows air flow to go under it. Have never heard the roof make anymore noises. I think what is happening here is my older strobe mount caused restriction and then it would cause the roof to make that noise. I never popped off the head liner, but I would venture to think that the roof may lack support brackets or something, because i had the same strobe light mounted on a F250 and the roof never made any noises from buckeling. I think your camper causes the wind to be blocked and forced under that small area. Maybe if you could make some sort of reflector sheild to help with areodynamics, you could stop this from happening. You see alot of big rigs that have this angled sheild on them which helps with air flow by redirecting it in a more areodyamic way.
I would be concerned about having the roof buckeling over time, that it might cause paint to become damaged from constant flexing, especially in different temps.
Yep, one of the complaints about my previous ex cabs. That buckling sound on rough roads. Problem is non existent on my crew cab thanks to the ribbing on the roof.
Get used to it.
Or find a way to keep the air from getting between the two. Add a skirt to the camper maybe. I only have this problem when I have my windows down and it is super windy outside. Even then it's only occasional
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
