Smooth And Paint
i am wantinh to smooth and paint my door handles, fender flares and '06 style towing mirrors to match my black 01 silverado. i amin serious need of help on doin this. i would like to do it my self if not too difficult. i have never done any thong like this so like said the more help i can get the better.
that would work for the handles, but what bout fender flares and mirrors though. i could just buy a different set, but then i would have a set just wasting shelf space. be easier for me just to paint what i got.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
