Nbs Lights Question?
I have a 2007 GMC Sierra and had a foglight go out a few weeks ago and this morning noticed one of my headlights are out. What bulbs are you guys using in fogs and headlights? Would like something bright. Has anyone used HID's and if so what brand?
