Extended Cab Passenger Side Rear Door Squeak - How To Fix It?
I have a 2007 NBS Silverado 2500HD extended cab, and the passenger side rear ("suicide") door squeaks badly when no one else is in the vehicle. However if I have a passenger, or about 100lbs at that side, then the extra weight stops the squeak from happening. I think I need to adjust the door catch somehow but I do not see any adjustment that I can make.
I've tried cleaning the rubber seals and applying silicone - lasts less than on week. I've tried the 3M squeak reducing tape as suggested by Chevy - lasted about 4 to 6 weeks before it started again. Now I am looking for a permanent fix by adjusting the door. The drivers side door does not have this issue. It is blissfully silent :rolleyes:
Any suggestions?
My '08 extended cab started doing that. Just adjust the catches on the door frame in little by little until the squeaking stops. It doesn't take much adjustment to fix the issue, so don't go crazy with it. Being that it doesn't do it with weight on that side suggests that it's most likely the lower catch, so adjust that one first.
I had a good look tonight. Compared to the driver side (which does not squeak) it appears the passenger side upper catch is not pulling the door as tight to the seals as on the driver side. There is a very slight play, and the squeak is coming from that passenger side upper seal. So pretty sure that is the problem.
But how to you adjust that catch? I cannot see any adjustment on the door side of the catch that would pull the door in tighter. On the car side it looks like the three bolts fit through holes in the fitting and there is little to no adjustment room there. Also it looks like I'd need to remove the seat belt to get the trim piece out before I could access the three bolt heads.
Any hints on adjusting the upper catch?
The other possibility is to adjust the hinge. I had to have the hinge adjusted when I first purchased the truck because of bad fit at the edges of the two doors. I do not know if that is now causing the slight play in the catch.
    ballencd
    ballencd
  • Who's Online   6 Members, 1 Anonymous, 667 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
