Front Door Armrest Discoloration
The portion I'm talking about here is where the hole is your and goes through and back from there. No matter what I put on the rubber I can't get rid of the white color. The one on the passenger side is worse then the drivers side but both are discoloring.
Any suggestions? :loser:
I think this is just from the oils on your skin getting on it when you grab it. Mine do the same thing. I clean it with Meguiar's Quick Interior Detailer and then Meguiar's Natural Shine protectant. Makes it look normal again. At least until you touch it enough to wear it all off.
I'll give that a try but the discoloration actually is over this entire piece. :lol:
I have a similar situation, but mine has a slight discoloration from the grab handle portion back. It's a gray color.....same with the passenger airbag 'cover', it's not the same color as the dash.
Go to the dollar tree and pick up some "AWESOME CLEANER" It sells for a dollar. Cut it with 50% water, spray your door handle and if it is in any way dirt, oil or grime..it WILL come off. If this cleaner does not do it...then you have a dye problem. Just contact a local car dealership and ask the used car manager what outside vendor he uses for interior dye work. He will usually tell you without hesitation.
Ok I'll see if I can find this stuff. Thanks! :dunno:
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
