Trans Temperatures ?!?!?!?!
Ok, i was on a rescue mission past night, had to use my Chevy to pull out a 44" Nissan Patrol, wich had dug himself into wet sand....
This was a incredibly tough rescue, but i was the only one available with a truck wich weighed over 2000kg !
I was able to pull him out, but just as i pulled him out... the hose coming off the top of the coolant reservoir popped off and i had smoke coming from pretty much everywhere.... i immediately shut off my engine, but was able to take a glinch at my gauges first and they read:
Trans Temp: ~270°F
Water Temp: ~250°F
I haven't yet been able to top up with coolant / water, but i will soon...
What are normal operating temperatures under heavy load...
This was 30 minutes of HEAVY pulling... almost half tank of gas !
Both temps were a little high quite frankly. Anything I've ever towed, I've never seen my engine temps above 210 and my tranny above 195. I'd SERIOUSLY consider a Royal purple Max aft fluid swap for the trans. It REALLY keeps the temps down. Either that or the new Dexron VI (semi-synthetic).
Depending on the situation, I can certainly see why the temps went up.. just lack of air flow thru the motor. I wouldn't be to worried about it, but maybe your due to make some upgrades for an added measure of security and piece of mind.
That trans temp is a little toasty. You might want to look into an auxillary cooler for it, or if you have already, a larger one
+1
If you do a lot of pulling guys out of bogs get one with a fan on it.
Like this one;
This is most definately on the upgrade list, along with some better trans-fluid !
Got out today and started the truck, everything seems ok, yet...
Wish i had taken some pictures, everyone was stunned to see a 33" Chevy pull out a 44" Nissan Patrol, considering he was up to his doors in quicksand.....
and the sound of the straight pipe roaring for 30 minutes while i was at it... it could make any person crazy :')
I have a auxilary cooler i think, since my truck has a Heavy Duty Tow Package ?
Z82 & Z85
270 is scorching for a tranny! I do a lot of towing and the highest temp I ever saw on my tranny temp gauge was around 200-210 and that was going up Mt. Eagle pulling a car on a trailer.
I would definitely suggest upgrading the cooler. The factroy ones are nice, but one with a nice fan on it will definitely be a big help.
... hey, I guess you thought that this rescue was absolutely necessary... but this is what professional tow trucks are for!!!!!
.. you saved someone a bundle for a tow truck, but you have definitely taken a BIG toll on your transmission to do this! Half an hour at that temperature will do major damage to your transmission.... oh, it will work ok for now... right up to one day when it quits suddenly.
.. and you overheated your engine too... what does that do to your maniford gaskets....?
I don't beleive you understand the situation we were in there, no tow truck was able to get down where he was stuck, and with the sea coming in we had to get that truck out within 2 hours or he would have had to get himself a new truck!
Insurance here never covers off-roading !
On the other half, owner of the Nissan is willing to pay ALL expenses that will occur because of this, i have his signed aggrement on that !
That being that my transmission is blown, he will pay for a new one, my motor being blown, he wil buy a new one !
I have no significant worries on the motor, the tranny is what worries me most, but i will most definately look into upgrading my tranny cooler and most definately install a deeper transmission pan!
Shitty deal man....too bad you didnt blow up something...a new engine and trans would have been sweet... :D:cool::D
At most man you probably destroyed the trans oil. you may have burnt up some clutches, but if everything is shifting good you should be fine.
I would however do a full fluid flush and filter change. you may as well get the cooler and deep pan at the same time. But don't wait too long...like within the next week if possible.
Oh on a related, but different topic, maybe you should build your truck up to be an off road rescue vehicle. There could be a lot of money had if no one does this where you are.
Well, seems everything is good...
i however notice that the fluid is as suggested by you nytemare, burnt up...
i've done 40km on it now, and it trends to heat up... called the dealership and they said this isn't unusual since the fluid is 100% burnt up...
wich fluid is the best for towing applications ?
nota bene, truck has only got 19500miles on it :D
Service it now. You can use Dex VI since it's synthetic and GM is using it in all their applications now. There is of course all the other synthetic brands: Amsoil, Mobil 1, etc.....
    Patrick Fergy
    Patrick Fergy
  • Who's Online   3 Members, 0 Anonymous, 779 Guests (See full list)
